September 03, 2010, 05:29:18 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
Welcome to the Kappa Performance Forum.
  Home   Forum   Calendar Links Gallery Login Register
Thank you for visiting the GM Kappa Performance Forum. This forum is the only performance oriented forum for all GM Kappa Platform Enthusiasts. Take a look around! We hope you will join and share your experiences. Becoming a member is FREE! If you want to advertise on this forum, email KappaPerformance at yahoo.com.
Guest rules are as follows:
* View and search posts
* Cannot view attachments
* Many Advertisements.
Membership has many advantages. More information on becoming a supporting member or vendor can be found here:
Click FORUM > Site Help and Suggestions > Supporting Members & Vendors.
Or by clicking here --> Supporting Member and Vendor Information
Google Search within the Kappa Performance Forum
Pages: [1] 2   Go Down
  Print
Author Topic: How to: Install heated seats  (Read 1106 times)
DeepBlueGXP
KappaPerformance Site Owner
Gearhead
Offline Offline
My Ride: 07 Solstice GXP
Displaced Buffalo Bills Fan
WWW
« on: January 28, 2010, 10:44:53 PM »
Getting photos up, will add more text tomorrow.
Remove seats. Each seat is held in by 4 bolts, 15mm.  The drivers seat has a power connector underneath and the passenger has the airbag sensor connector under it.  The seat belt is held on with a #50 torx.  It doesn't have to be removed to do the install but this makes it simpler.
I partiall removed the seat covers.
Seat backs:
The back was the easiest.  Unzip both zippers to the top, then pull the flap to the side until it detaches from the bottom clip.  Pull back the side that doesn't have the release knob.  When separating the velcrow strips, keep a finger pressed agains the velcrow on the seat to prevent it from separating.  Pull the cover up and over the top.  Install the heated seat kit as below in the photos.  Pull the cover back over and work the velcrow back into the groves as you lower the cover.  Tuck the heated seat cable to the side of the seat that is closest to the center of the car.   When you are ready to zip tie the cable below the seat, make sure the seat is full released forward and then secure the cable.  (if not, you will damage the cable the next time you move the seat back forward)
Seat Bottoms:
If you have seat adjuster
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000128.jpg
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000129.jpg
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000130.jpg
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000132.jpg
Place pad on seat (not the iPad) and draw where to cut for the seat cover velcrow
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000133.jpg
Place on hard surface
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000153.jpg
Use a ruler to mark the edge as to where to stop cutting
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000154.jpg
Mark both sides
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000155.jpg
Use ruler as straight edge
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000156.jpg
Cut carefully on both sides of marked line
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000157.jpg
Cut out section, I left about a half inch to the side element
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000158.jpg
Done cutting
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000125.jpg
Test fit on car and route cable
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000126.jpg
Peel off adhesive layer.  (one set didn't come with it so I had to spray glue on)
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000127.jpg
Zip tie on relay
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000135.jpg
removed center console lower section.
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000139.jpg
Next two are passenger seat photos
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000142.jpg
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000143.jpg
Passenger seat side piece held in with plug
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000145.jpg
Relay on passenger seat bottom
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000147.jpg
Drilled two holes with 3/4 hole saw
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000152.jpg
Routed wires beneath radio
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000136.jpg
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000137.jpg
Finished product
http://i893.photobucket.com/albums/ac132/kappaperformance/2010-01-23%20Heated%20Seats/P1000159.jpg
« Last Edit: January 29, 2010, 12:27:35 PM by DeepBlueGXP » Logged
Author Topic: How to: Install heated seats(Read 1106 times)
JET WS6
Junior Member
Online Online
My Ride: 08 Sky Red Line
« Reply #1 on: January 28, 2010, 11:09:04 PM »
Excellent reference guide.  I'll be doing this mod in the next week or two.  Can't wait.
Logged
2008 Midnight Sky RL
GMPP Stage II
6000K HID High/Low/Fog
Hardwired Radar Detector
Gentex Auto-dim mirror
Integrated Homelink
Side Marker Signal Mod
GMR Sequential Turn Signals
GMR Fender Vent Lights
JPM Center Console
JPM Seat Belt Loops
WindRestrictor V1
WindRestrictor Lit Door Sills
Opel GT Rear Fog
G2 Painted Calipers
15% Tint
I am a GM engineer.  All of my posts are my own opinion.
sunnygator
Senior Member
Offline Offline
My Ride: Cool 07 Solstice GXP w/GMPP
« Reply #2 on: January 29, 2010, 12:32:52 AM »
Thanks for the picts Joe, but it just convinces me that I should should wait for the mod meet where I'll have some expert and needed support....I really do like where the switches are mounted in your install.
sunnygator
Logged
DeepBlueGXP
Gearhead
Offline Offline
WWW
« Reply #3 on: January 29, 2010, 07:37:02 AM »
Thanks to 2KWK4U and Critterman for that location of the switches.
Logged
Critterman
Gearhead
Offline Offline
My Ride: 06 Solstice Roadster, 2.4 DDM Stage III Supercharged
Baltimore/Washington Corridor
« Reply #4 on: January 29, 2010, 10:14:07 AM »
Joe, didn't you have to drill into the actual dash panel behind where you mounted the switches?  Mine was solid behind the snapin panel and we had to drill there as well.  3rd and 2nd picture from the end. The panel behind the panel with the switches.
Logged
2006 Cool named BIXABEL  Mayan for "Good Roads"
StageIII intercooled Supercharger w/CAI
big brake kit w/Hawk pads & blue juice
HKS Coilover suspension
Lambo Doors
burnout GO N.A.K.3.D..
DeepBlueGXP
Gearhead
Offline Offline
WWW
« Reply #5 on: January 29, 2010, 10:50:58 AM »
Mine had a space about 1 inch and I found that when I cut back the large heat shrink behind the switch, the wires were able to bend over and not interfere.
Logged
2kwk4u
not really THAT quick
Senior Member
Online Online
My Ride: '08 Solstice GXP
WWW
« Reply #6 on: January 29, 2010, 05:51:40 PM »
6:1, half dozen:the other
I just did a little weight reduction mod to Critter's car while I was at it with the install LOL
Logged
'06 bought and sold to move to Germany
'08 GXP bought and stored 10 months before moving HOME from Germany
Critterman
Gearhead
Offline Offline
« Reply #7 on: January 30, 2010, 07:15:20 PM »
every oz helps when hauling my fat @$$ around
Logged
Lambo Doors
Boosted Wicked
Junior Member
Offline Offline
My Ride: 2009 Pontiac Solstice GXP
« Reply #8 on: February 24, 2010, 02:51:09 PM »
im wondering why did u cut the slits in the pad? did this affect the pad at all or is it cuttable?
Logged
2kwk4u
Senior Member
Online Online
WWW
« Reply #9 on: February 24, 2010, 05:37:22 PM »
No affect on the heating elements, so long as you're using the pads with carbon fiber circuits, at least.  You can make slits across the middle of the pad, width-wise, so long as you don't go across the edge.  Our seats covers are held on with hook and loop (velcro) fasteners.  The slits allow the seat pad to stick to the seat cushion still.
Logged
DeepBlueGXP
Gearhead
Offline Offline
WWW
« Reply #10 on: February 24, 2010, 06:29:58 PM »
Concur with 2KWK4U!
Logged
ThunderSky
Member
Offline Offline
My Ride: 07 Sky Redline
« Reply #11 on: February 24, 2010, 11:00:41 PM »
Hey Guys
My kits each include an adhesive backed, silver colored sheet of some kind. dont know
Any idea what that's for ????
« Last Edit: February 24, 2010, 11:08:20 PM by ThunderSky » Logged
ThunderSky
Graphite RedLine,
Red / Black Leather,
Manual Tranny, Windrestrictor,
Monsoon with XM , Spoiler,
8000K HIDs on Low Beams and Fogs
Drilled/Slotted Rotors, Painted calipers,
Magnaflow 3" Quad Tip Exhaust, CAI
2kwk4u
Senior Member
Online Online
WWW
« Reply #12 on: February 25, 2010, 05:50:45 AM »
According to the engrish directions, the best I can tell is that those stickers (mine were perforated in strips, Critter's were not) are intended to act as insulators in hog ring-type seats.  You're supposed to wrap the metal rods in them and they are supposed to prevent those rods from wearing holes in the heating elements and shorting out.
Logged
polysci
Junior Member
Offline Offline
« Reply #13 on: March 02, 2010, 02:27:26 PM »
What did you do about the electric? I'm at that point in my install and trying to figure out where to run the NEG line to. Back to the battery or catch something under seat or dash?
Thanks. dont know
Logged
TomatoSoup
Senior Member
Offline Offline
My Ride: 2008 Solstice GXP (Brazen) "Campbelle"
« Reply #14 on: March 02, 2010, 02:31:01 PM »
There's a grounding bolt on top of the transmission tunnel between the seats, under the center armrest.  You can just use that.
Logged
polysci
Junior Member
Offline Offline
« Reply #15 on: March 02, 2010, 02:41:05 PM »
I don't know why I had a brain fart here, the kit comes with red and white leads. Since it wasn't black I didn't think to just run it to the body. Doh!
Thanks tomatosoup.
Logged
odiaz
Member
Offline Offline
My Ride: 07 Deep Solstice GXP
Deep GXP
WWW
« Reply #16 on: March 02, 2010, 11:21:16 PM »
Thanks for the excellent write up and pictures Joe.  My heat pads just arrived today.  We're supposed to have 50 degrees here on LI this weekend.  It might be a good time to put them in.  I'm going to try to do the saggy seat fix at the same time using JPM's directions.
I copied all of your pictures and instruction to a dedicated web page and added some comments that I read from other posts about this topic.
http://www.cherod.com/solstice/HowTos/HeatedSeats.htm
I had a question about the switch location. I thought it might be more convenient to have the switches mounted closer to the passenger and the driver.  I was thinking of mounting them on sides of the shifter tunnel as show in this picture.
http://www.cherod.com/solstice/HowTos/HeatedSeats_files/image051.jpg
From the pictures, it looks like there  might be enough clearance to mount the switches somewhere along these sides.  What do you think?
« Last Edit: March 03, 2010, 01:40:13 AM by odiaz » Logged
DeepBlueGXP
Gearhead
Offline Offline
WWW
« Reply #17 on: March 03, 2010, 06:49:47 AM »
There isn't much space on the sides for the depth of the switches and the harness.
Logged
DeepBlueGXP
Gearhead
Offline Offline
WWW
« Reply #18 on: March 03, 2010, 07:05:06 AM »
Odiaz, Looked at your page on the seats.  Nice.  If you look at the second to last photo, there is a black wire at the bottom right with a blue crimp connector barely showing.  That is the location to ground them.  You can take off your center console and see the stud sticking up.  Also, each seat comes with a in-line 10a fuse so I soldered the power wires together keeping those fuses and then soldered them to a 20a fuse tap.
Logged
TomatoSoup
Senior Member
Offline Offline
« Reply #19 on: March 03, 2010, 11:03:21 AM »
Don't know if there's enough depth there as DBG says.  But in any case, I personally think it's a bad idea to have the passenger switch out of sight of the driver.  Very easy to leave it on and not realize it.
Of all the switch mount places I've seen, I prefer the way that I and 2kwk4u did it -- above the radio, below/between the A/C knobs (of course I may be biased).
Smile
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
Text Version
Random Image Gallery
Our Vendors
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.108 seconds with 26 queries.
Google visited last this page August 24, 2010, 10:04:22 AM
