September 03, 2010, 05:31:02 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
Welcome to the Kappa Performance Forum.
  Home   Forum   Calendar Links Gallery Login Register
Thank you for visiting the GM Kappa Performance Forum. This forum is the only performance oriented forum for all GM Kappa Platform Enthusiasts. Take a look around! We hope you will join and share your experiences. Becoming a member is FREE! If you want to advertise on this forum, email KappaPerformance at yahoo.com.
Guest rules are as follows:
* View and search posts
* Cannot view attachments
* Many Advertisements.
Membership has many advantages. More information on becoming a supporting member or vendor can be found here:
Click FORUM > Site Help and Suggestions > Supporting Members & Vendors.
Or by clicking here --> Supporting Member and Vendor Information
Google Search within the Kappa Performance Forum
Pages: [1] 2 3 ... 9   Go Down
  Print
Author Topic: Kappa Specific Sound Deadening Kits  (Read 7499 times)
Rudeboy
Member
Offline Offline
WWW
« on: July 20, 2009, 03:39:55 PM »
I'll be preparing kits for the upcoming meet and will be delivering them. No shipping charge, but Maryland Sales Tax will apply.
Here they are:
Doors - everything you'll need including Africa pieces for the access holes: $97.10
Floor: $115.76
Back Wall: $74.32
Trunk: $85.40
You'll also need an 8 oz can of HH-66 for $8.50.
Any 3 kits gets 5% off the total. All 4 kits gets 10% off.
Here's what you would need for a complete car from the standard catalog - seems to work for both the convertible and coupe and for the Solstice and Sky.
45 CLD Tiles @ 2.25 = $101.25
1 roll Extruded Butyl Rope @ 8.75 = 8.75
1 67.5 ft² roll MLV @ 121.50 = 121.50
2 sheets 1/4" CCF @ 27.65 = 55.30
2 sheets 1/8" CCF @ 14.95 = 29.90
1 Velcro Patches, adhesive 2 sides, 10-pack @ 14.65 = 14.65
1 8 oz can HH-66 Vinyl Cement @ 8.50 = 8.50
Sub Total: $339.85
Shipping will depend on your location
Wyatt (TecSolOnt) managed to get some CCF behind the MLV on the back wall. This is a good idea. I'm not sure if he used scraps or something else, but you might want to add another sheet of 1/4" CCF for that. Scraps of CCF are very handing for stuffing behind other trim panels as well.
The MLV roll is 54" wide which works out very well for this project. Cut two 18" pieces for the the doors and trim the length to 37". The back wall wants a 36"X54" slice. The floor needs two 26"X54" pieces.
Two of the CCF sheets should be cut 20"X54" for the floor. Reserve the 16"X54" piece for the doors. The third sheet goes into the trunk.
CLD Tile distribution is pretty simple: 5 each outer door skin. Cut 1 tile into smaller pieces for the inner door skin. The floor gets 14 (remove the stock deadener first) distributed over the resonant, unsupported areas. 4 for the back wall and 9 for the trunk.
If you want to treat less than the full car, let me know and I'll figure out what you need.
I'll throw in a set of the aluminum "Africa " pieces (door inner skin access hole covers) to anyone who buys the material to treat their doors and at least one other area of the car.
« Last Edit: April 11, 2010, 11:58:41 PM by Rudeboy » Logged
Author Topic: Kappa Specific Sound Deadening Kits(Read 7499 times)
Critterman
Gearhead
Offline Offline
My Ride: 06 Solstice Roadster, 2.4 DDM Stage III Supercharged
Baltimore/Washington Corridor
« Reply #1 on: July 20, 2009, 09:40:17 PM »
Rudy,
What would the install run for locals at you shop?
Logged
2006 Cool named BIXABEL  Mayan for "Good Roads"
StageIII intercooled Supercharger w/CAI
big brake kit w/Hawk pads & blue juice
HKS Coilover suspension
Lambo Doors
burnout GO N.A.K.3.D..
Rudeboy
Member
Offline Offline
WWW
« Reply #2 on: July 20, 2009, 10:06:27 PM »
Rudy,
Sorry Critterman, this is strictly DIY. While it isn't difficult, it is time consuming. I'm working on the step-by-step right now.
Logged
LiquidPT
Senior Member
Offline Offline
Facebook: LiquidPT
My Ride: 09 Mysterious Solstice GXP Coupe
TechHead
WWW
« Reply #3 on: July 20, 2009, 10:45:36 PM »
 Drool
what's the reason for the different floor packages?
Logged
LiquidPT aka Matt
driving Black Sun
Rudeboy
Member
Offline Offline
WWW
« Reply #4 on: July 20, 2009, 10:54:50 PM »
I'll get to that in the details, but the less expensive one is meant to use if you leave the stock vibration damper in place - it has 6 CLD Tiles instead of 14 since there's not a lot of point in placing vibration damper on top of vibration damper. The stock material is not very effective but it will take a few hours to remove. If the stock stuff is in good shape, there's not a huge performance gain to be had from replacing it, but it will very likely deteriorate after a few years since it is asphalt.
Logged
spicy3480
Solo Performance Sales
Gearhead
Offline Offline
Facebook: Steve Mariano
« Reply #5 on: July 20, 2009, 11:10:17 PM »
That's a very nice price...about 360 for everything.  I will be getting this for the meet in October...now if only Joe will help me with the install. Smile
Logged
I have "The Sickness" (according to baconbits, it's an "auto" immune disease)
LiquidPT
Senior Member
Offline Offline
Facebook: LiquidPT
TechHead
WWW
« Reply #6 on: July 20, 2009, 11:26:39 PM »
OK, that's kinda what I figured... My car is brand new, so it should be in good shape.. wink
I'll eventually need to figure out the trunk on a coupe. I want to pull the carpet anyways to run some LEDs, but Joe might beat me to it.
Logged
LiquidPT aka Matt
driving Black Sun
Rudeboy
Member
Offline Offline
WWW
« Reply #7 on: July 21, 2009, 12:31:38 AM »
Doors
First you have to take them apart. Disconnect the negative battery terminal. Remove the phillips head screw on the end of the door.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_01.jpg
Unclip this cover by moving the tab (to the left on this side) and pulling the cover out.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_02.jpg
Remove the phillips head behind the cover.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_03.jpg
Pop out this panel.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_04.jpg
Remove the 2 bolt head screws.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_05.jpg
The trim panel is now only held in place by plastic clips. Pull it straight out, starting at the bottom. A panel popper will be very helpful. When it come free lift it over the lock knob to give yourself some space and disconnect the wire harness connectors and the door handle cable.
Peel off the vapor guard and throw it away. The adhesive is a very gooey butyl compound. The best way to clean it up is to roll some up into a ball and use that to poke at the adhesive still on the door. It will pull it right off.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_06.jpg
Remove the bolt head screw at the top of the speaker.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_08.jpg
Pull the top of the speaker away from the door until you hit the clip. Press down on the clip from the top to release the speaker. Disconnect the wire harness.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_09.jpg
Working through the large access hole, remove the black styrofoam block. There are 3 christmas tree clips holding it in place. Work them free with a screwdriver or panel popper and work the block out of the door. You will be putting this back after applying CLD Tiles to the exterior sheet metal. Don't Forget!
Grab hold of the stock butyl/foil vibration damper and pull it out. We'll be replacing it with something much more effective. Pick out any butyl that separates from the foil.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_10.jpg
Here's what the block looks like out of the car
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/dis_11.jpg
Now you're ready to install the materials in the door kit.
« Last Edit: July 21, 2009, 09:52:33 AM by Rudeboy » Logged
Rudeboy
Member
Offline Offline
WWW
« Reply #8 on: July 21, 2009, 01:09:09 AM »
Door Kit - Part 2
Time to install the CLD Tiles to the exterior door skin. You will be installing 3 tiles above the crash intrusion protection structure and a 4th - cut in half along its length. Wipe down the surface with denatured alcohol to remove dirt and any greasy residue. No matter how clean your car is, the insides of your doors are probably dirty.
The best way to install the tiles is to peel back an inch or so of the release paper, press the tile in place and start peeling and pressing until you have the paper completely off. You don't want any air bubbles between the tile and the sheet metal. Go over the tile with a roller.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/tiles.jpg
Put the styrofoam block back in
To seal or not to seal?
I always seal the access holes in the doors I work on. The advantages are that it reduces noise transmission, makes the door more rigid and less resonant and turns your door into something closer to a proper speaker enclosure. The down side is that the edges of the holes aren't all in one plane so you can't just cut a piece of aluminum stock and screw it in place unless you are pretty good at shaping sheet metal. You can do this with a variety of materials but you want the covers to be as rigid as possible, waterproof, non-corroding and removable.
I made fiberglass covers for Bobby's doors. This is a good way to go but it is very time consuming. I'm not going to show the details of how I built them because I really don't want to encourage anybody to do this unless they have experience working with the stuff.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/fg.jpg
John and I did his doors using a double layer of aluminum flashing you can buy in the roofing department at Home Depot with a layer of butyl between the to layers of aluminum. This isn't as rigid as fiberglass, but you can cut the flashing with heavy scissors. The sandwich is flexible enough to be pushed into the contours and the butyl layer makes it very non-resonant. This image also shows how you should cut up and apply a CLD Tile to the interior door skin.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/flashing.jpg
Here's how to make the flashing "sandwich". Cut your 2 matching pieces of flashing for each hole. Partially cover one side with Extruded Butyl Rope. Press the 2 sides together with the butyl at the center. Put the sandwich on some aluminum foil and put it in a 250°F oven for 30 minutes. Take it out and go over it with a roller. This flattens the butyl and spreads it over the entire surface.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/flashing_sandwich.jpg
Whatever you make the covers out of, run a bead of Exruded Butyl Rope around the mounting surface before pressing them in place. This will improve the seal and will add more vibration damping to the door. Hold in place with self tapping screws or a fastener of your choice. Remember that doors are exposed to water. If you drill pilot holes for your fasteners, priming and painting them is a good idea. I use a good coating of Loctite too.
Next up - applying the mass loaded vinyl and closed cell foam.
Logged
Rudeboy
Member
Offline Offline
WWW
« Reply #9 on: July 21, 2009, 11:06:44 AM »
Door Kit - Part 3
Now we're ready to fit the mass loaded vinyl (MLV) to the interior door skin. The goal is to cover as much of the door as we can and still get the trim panel back on. Any holes we make in the MLV to fit wires and for the door open cable to pass through should be as small as possible. If we make a mistake, it can be repaired using HH-66 Vinyl Cement.
First hang the MLV using Velcro patches. The patches are large enough and strong enough that you should cut them in half for easier positioning. Peel the release film off of one side of the Velcro and press it onto the door along the top edge where you will be mounting the MLV. Repeat so that you have two mounting points. Peel the release film off of the the 2 Velcro pieces mounted to the door. Align the MLV and press into place. To assure that the Velcro adhesive is firmly affixed, Peel the MLV off the door, separating the hook and loop sides of the Velcro. Press down the sides mounted to the door and the sides mounted on the MLV.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/mlv_01.jpg
This shows the positions of the Velcro patches after the door is complete. At this point just put 2 along the top and the one at the top right doesn't need to be a whole strip.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/velcro.jpg
Trim the MLV to allow clearance for the clips.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/mlv_02.jpg
Pull the egg crate looking plastic piece off - it's just hot glued in place. Throw it away.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/egg_crate.jpg
Take note of the bracket and screw slots.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/screw_slots.jpg
Here you can see the cutout for the bracket and the hole I'll have to come back and fix.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/screw_slots2.jpg
Remove the MLV from the door and lay it inside the trim panel for fine tuning. There's a lot of information in this photo.
1) I cut the MLV to allow the bracket in the last photo to just fit through. I then covered the hole with a scrap of 1/4" CCF using HH-66 Vinyl Cement. This way, when you screw the trim panel back down you will still have a tight seal and the CCF will eliminate any possibility of rattling.
2) This was a mistake I made and repaired with a scrap of MLV using HH-66. When I had the MLV mounted to the door I cut the MLV to match the hole behind the handle. Not necessary - plenty of clearance without cutting the MLV. HH-66 creates a bond that is stronger than the vinyl itself. No harm no foul.
3) The MLV overlaps the black styrofoam inside the trim panel. This will make the trim panel impossible to get back on. You'll need to cut the styrofoam down 1/8". I used a sanding drum on a Dremel - zip zip, done.
Finally, notice the little extension pieces of MLV on the left side and the bottom. Again. MLV scraps and HH-66. May as well fill that panel as much as possible. Also notice the amount of clearance around the clips and alignment rods.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/mlv_04.jpg
Getting ready to wrap this up. Here ou can see the error I made (and repaired)  and the extra holes for the lock knob, handle cable, etc. Make sure that the hole you cut for the lock knob rob has enough clearance for both locked and unlocked positions. I cut the MLV so that it exactly fit the speaker opening so that the speaker goes back on top of the MLV. I've also added 1/4" CCF to the surface of the MLV using HH-66. You want to add as much as will fit.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/doors/mlv_05.jpg
Reassemble door. Done.
« Last Edit: July 21, 2009, 11:16:45 AM by Rudeboy » Logged
Rudeboy
Member
Offline Offline
WWW
« Reply #10 on: July 21, 2009, 11:54:09 AM »
Floor Kit
First things first. If you are going to do the Floor Kit you really ought to do the back wall kit too and at the same time. You need to remove the back wall to do the floor and the two areas sort of run together.
Remove the negative battery terminal.
Slide the seat forward and move the seat back forward to give yourself some space. Remove the nuts holding the seat down. Unscrew the black plastic carpet hold down. It has an allen wrench fitting but you can unscrew it by hand. (Battery not required Smile)
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/seats_01.jpg
Slide the seat back and remove the front nuts. Tip the seat back and disconnect the wire harness connector(s). Lift the seat out of the car. Remove the other seat. Pop the door sills off.
Remove the back wall side trim pieces. That's Bobby, but it's my pink panel popper so you can't hold that against him ) Remove the speaker connector.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/side_trim.jpg
Pop of the center console/hump trim . Pop off the back wall trim.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/back_wall_trim.jpg
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/trim_removed.jpg
Remove the dead pedal and remove the carpet from both sides.
You should be looking at this.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/carpet_removed.jpg
Next - to scrape or not ...
« Last Edit: July 21, 2009, 10:06:43 PM by DeepBlueGXP » Logged
Rudeboy
Member
Offline Offline
WWW
« Reply #11 on: July 21, 2009, 01:00:14 PM »
Floor Kit - Part 2
Here we are. Notice the box bolted to the passenger side floor. Remove the nuts that hold it down and remember its orientation. We're going to cut the CCF and MLV so that it still makes contact with the floor when we put it back.
This where you decide which Floor Kit you will be buying based on whether or not you want to scrape out the factory vibration damping on the floor. It looks OK in this picture but it had lifted up from the floor in a few places and had never been bonded to the floor in others. Air space between a vibration damper and the substrate renders the vibration damper completely worthless.
I was pretty disappointed to run into this stuff in this car. It's asphalt with some sort of metallic/metalized coating on top. Right next to it there is a very high quality material used on the center hump. For whatever reason they cheaped out big time on the floor. I won't go into all of the reasons why asphalt is a very poor vibration damper and why it shouldn't be considered a permanent material for use in motor vehicles.
The fact is, if yours is in reasonable shape, there will only be a small improvement in noise reduction if you talk it out. We're going to go over this surface with CCF and MLV anyway and that will account for most of the noise attenuation. Whether you leave it or take it out is going to be ore a function of the kind of person you are. If trading 2 hours of your life seems absolutely worth it to know that you have done everything possible or if you want to know that the vibration damper on the floor won't be causing any problems in 20 years, take it out. You know who you are Smile If you are going to leave it in there, go ahead and skip to the next section.
Now that the slackers are gone we can get down to business wink The good news for those of you who will be removing the asphalt is that asphalt melts at 180°F. That's bad for durability but means you can scrape most of it out with a heat gun and a putty knife. Being careful not cut into the e-coat, warm an edge of the asphalt, slip the putty knife under it and work you way across.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/asphalt_01.jpg
Once you've gotten everything up you can by heating and scraping, use a shop vac to get up all of the brown grit you couldn't pick up by hand.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/asphalt_02.jpg
Now it's time to add some mineral spirits. You'll also need some rags or paper towels. Pour an ounce or so of mineral spirits onto an area with residue remaining. Spread it out with your putty knife and let it set for a minute or so. Use the putty knife to gently scrape the residue away. Use a rag to wipe up the glop. When you're done, Put some mineral spirits on a rag and wipe the surface down. Finish up with a denatured alcohol wipe down to get rid of any oily residue. Now you have a nice clean floor. You get points for dedication. If you want points for being a hard-ass, use an acetylene torch like Bobby did on his side.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/no_asphalt.jpg
Next - applying CLD Tiles to the floor.
« Last Edit: July 21, 2009, 09:19:51 PM by Rudeboy » Logged
Rudeboy
Member
Offline Offline
WWW
« Reply #12 on: July 21, 2009, 09:46:23 PM »
Floor Kit - part 3 We start installing stuff!
If you left the stock vibration damper in place, your best bet is to apply the 6 CLD Tiles in your kit to the untreated portions of the floor. There isn't much to be gained by applying them on top of the existing material.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/cld_tiles_with_stock.jpg
If you took your floor down to the e-coat, something like this is the way to go. The brown stuff you see isn't rust. It's asphalt dust that stuck to the joint caulk because we didn't have a shop vac to suck it up. Won't hurt anything.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/cld_tiles.jpg
Everybody's the same from here on out. Lay one of the CCF sheets on the floor and trim it to just cover the horizontal surface. Here you can see the cut-out for the block that bolts to the floor.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/ccf.jpg
Lay the MLV on the floor. You want it to run up the door sill a litle bit, up the firewall/foot well as far as it will reach and as far up the center hump as it will reach. Press down on the MLV above the threaded studs and they will break through. Make sure to get them all. You will have to cut slits to get around the corners. Do it in a way that the resulting flaps overlap.
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/mlv1.jpg
http://www.sounddeadenershowdown.com/images/vehicles/kappa_kit/floor/mlv2.jpg
 You could put everything back together now, but since we've already agreed that you will do the floor and the back wall at the same time, I'll move on to the back wall next.
Logged
G8TR
Senior Member
Offline Offline
My Ride: 08 Sky RL
« Reply #13 on: August 04, 2009, 09:47:46 PM »
Rudy,
When will you be posting the back wall install?
Logged
SkyRider, Flying High in my Sky
Beach Party Fuse Box Cover, JPM Gators Seat Covers, JPM Gator Saddlebag, JPM Gator Sky Duffle, JPM Gator Console Cover, DDM Pro Beam, DDM Backbone, Painted Engine Cover, Painted Hood Liner, MBRP I/C Pipes, Hahn Intercooler, Solo Hi Flow Cat, Sequential Rear Turn Signals, Side Marker Light to Turn Signal Mod
Rudeboy
Member
Offline Offline
WWW
« Reply #14 on: August 04, 2009, 10:36:28 PM »
Rudy,
I'll be finishing up this week.
Logged
KWhale
Playing with my
Senior Member
Offline Offline
My Ride: 07 Solstice GXP
« Reply #15 on: August 04, 2009, 11:03:58 PM »
Rudy, these instructions are amazing!  Even for people who are not doing the sound deadening, the how-to-take-things-apart value is off the charts.  Thanks for taking the time to take all the pictures and posting them here.
Logged
http://kappaperformance.com/index.php?action=googlemap!
Rudeboy
Member
Offline Offline
WWW
« Reply #16 on: August 04, 2009, 11:33:53 PM »
Happy to do it. These cars are actually very nice to work on - the parts fit together very well and are designed to maintain their fit after repeated disassembly/assembly.
Logged
bluemangxp
Member
Offline Offline
« Reply #17 on: August 05, 2009, 03:25:47 PM »
Very nicely done how-to. Thanks for all the hard work and sharing with the members
Logged
Treeman
Senior Member
Online Online
My Ride: 09 Solstice GXP
« Reply #18 on: August 05, 2009, 04:06:53 PM »
Wow - great how-to!  Thanks!
Adding up the weight, it comes to 75 lbs.  In an earlier thread, you mentioned CLD tiles only would help and they would be about 6 lbs.  Can you talk a bit more about this choice - how much would the CLD tiles help in comparison to the full kit and also what would be the pricing for that?
Logged
DDM Race Backbone, ProBeam, and Coil Cover
BeachParty
Senior Member
Online Online
Custom Fuse Box Covers
« Reply #19 on: August 05, 2009, 07:18:14 PM »
Totally agree!! I love your attention to detail. Thank you!!
Logged
2007 Sly Solstice GXP
Pages: [1] 2 3 ... 9   Go Up
  Print
Jump to:
Text Version
Random Image Gallery
Our Vendors
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.131 seconds with 28 queries.
Google visited last this page August 28, 2010, 09:10:22 AM
