Author Topic: Kappa Check Engine Light (CEL) List  (Read 15241 times)
« on: December 13, 2008, 10:24:31 AM »
If you happen to get a CEL, goto your nearest Advanced Auto Parts or AutoZone.  The will do code scans and resets "FREE"  If you have a serious CEL code, take it your dealer for service.  DashHawk can read and clear CEL.
P0010 Intake Camshaft Position Actuator Solenoid Control Circuit
P0011 Intake Camshaft Position System Performance
P0013 Exhaust Camshaft Position Actuator Solenoid Control Circuit
P0014 Exhaust Camshaft Position System Performance
P0016 Crankshaft Position-Intake Camshaft Position Correlation
P0017 Crankshaft Position-Exhaust Camshaft Position Correlation
P0030 HO2S Heater Control Circuit Sensor 1
P0031 HO2S Heater Control Circuit Low Voltage Sensor 1
P0032 HO2S Heater Control Circuit High Voltage Sensor 1
P0033 Turbocharger Bypass Valve Solenoid Control Circuit
P0034 Turbocharger Bypass Valve Solenoid Control Circuit Low Voltage
P0035 Turbocharger Bypass Valve Solenoid Control Circuit High Voltage
P0036 HO2S Heater Control Circuit Sensor 2
P0037 HO2S Heater Control Circuit Low Voltage Sensor 2
P0038 HO2S Heater Control Circuit High Voltage Sensor 2
P0053 HO2S Heater Resistance Sensor 1
P0054 HO2S Heater Resistance Sensor 2
P0068 Throttle Body Airflow Performance
P0087 Fuel Rail Pressure Too Low
P0088 Fuel Rail Pressure Too High
P0089 Fuel Pressure Regulator Performance
P0090 Fuel Pressure Regulator Control Circuit
P0091 Fuel Pressure Regulator Solenoid 1 Control Circuit Low Voltage
P0092 Fuel Pressure Regulator Solenoid 1 Control Circuit High Voltage
P0096 Intake Air Temperature Sensor 2 Performance
P0097 Intake Air Temperature Sensor 2 Circuit Low Voltage
P0098 Intake Air Temperature Sensor 2 Circuit High Voltage
P0099 Intake Air Temperature Sensor 2 Circuit Intermittent
P0100 Mass Air Flow Sensor Circuit
P0101 Mass Air Flow Sensor Performance
P0102 Mass Air Flow Sensor Circuit Low Frequency
P0103 Mass Air Flow Sensor Circuit High Frequency
P0106 Manifold Absolute Pressure Sensor Performance
P0107 Manifold Absolute Pressure Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure Sensor Circuit High Voltage
P0112 Intake Air Temperature Sensor Circuit Low Voltage
P0113 Intake Air Temperature Sensor Circuit High Voltage
P0114 Intake Air Temperature Sensor Circuit Intermittent
P0115 Engine Coolant Temperature Sensor Circuit
P0116 Engine Coolant Temperature Sensor Performance.
P0117 Engine Coolant Temperature Sensor Circuit Low Voltage
P0118 Engine Coolant Temperature Sensor Circuit High Voltage
P0119 Engine Coolant Temperature Sensor Circuit Intermittent
P0120 Throttle Position Sensor Circuit
P0121 Throttle Position Sensor Performance
P0122 Throttle Position Sensor 1 Circuit Low Voltage
P0123 Throttle Position Sensor 1 Circuit High Voltage
P0125 Engine Coolant Temperature Insufficient For Closed Loop Fuel Control
P0128 Engine Coolant Temperature Below Thermostat Regulating Temperature
P0130 HO2S Circuit Closed Loop Performance Sensor 1
P0131 HO2S Circuit Low Voltage Sensor 1
P0132 HO2S Circuit High Voltage Sensor 1
P0133 HO2S Slow Response Sensor 1
P0134 HO2S Circuit Insufficient Activity Sensor 1
P0135 HO2S Heater Performance Sensor 1
P0137 HO2S Circuit Low Voltage Sensor 2
P0138 HO2S Circuit High Voltage Sensor 2
P0139 HO2S Slow Response Sensor 2
P0140 HO2S Circuit Insufficient Activity Sensor 2
P0141 HO2S Heater Performance Sensor 2
P0171 Fuel Trim System Lean
P0172 Fuel Trim System Rich
P0192 Fuel Rail Pressure Sensor Circuit Low Voltage
P0193 Fuel Rail Pressure Sensor Circuit High Voltage
P0201 Injector 1 Control Circuit
P0202 Injector 2 Control Circuit
P0203 Injector 3 Control Circuit
P0204 Injector 4 Control Circuit
P0218 Transmission Fluid Overtemperature
P0220 Throttle Position Sensor 2 Circuit
P0221 Throttle Position Sensor 2 Performance
P0222 Throttle Position Sensor 2 Circuit Low Voltage
P0223 Throttle Position Sensor 2 Circuit High Voltage
P0230 Fuel Pump Relay Control Circuit
P0234 Turbocharger Engine Overboost
P0236 Turbocharger Boost System Performance
P0237 Turbocharger Boost Sensor Circuit Low Voltage
P0238 Turbocharger Boost Sensor Circuit High Voltage
P0243 Turbocharger Wastegate Solenoid Control Circuit
P0245 Turbocharger Wastegate Solenoid Control Circuit Low Voltage
P0246 Turbocharger Wastegate Solenoid Control Circuit High Voltage
P0261 Injector 1 Control Circuit Low Voltage
P0262 Injector 1 Control Circuit High Voltage
P0264 Injector 2 Control Circuit Low Voltage
P0265 Injector 2 Control Circuit High Voltage
P0267 Injector 3 Control Circuit Low Voltage
P0268 Injector 3 Control Circuit High Voltage
P0270 Injector 4 Control Circuit Low Voltage
P0271 Injector 4 Control Circuit High Voltage
P0299 Turbocharger Engine Underboost
P0300 Engine Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0315 Crankshaft Position System Variation Not Learned
P0324 Knock Sensor Module Performance
P0325 Knock Sensor Circuit
P0326 Knock Sensor 1 Performance
P0327 Knock Sensor 1 Circuit Low Voltage
P0328 Knock Sensor 1 Circuit High Voltage
P0331 Knock Sensor 2 Performance
P0332 Knock Sensor 2 Circuit Low Voltage
P0333 Knock Sensor 2 Circuit High Voltage
P0335 Crankshaft Position Sensor Circuit
DTC P0335 or P0336 for the 2.4L engine
P0336 Crankshaft Position Sensor Performance
P0338 Crankshaft Position Sensor Circuit High Duty Cycle
P0340 Intake Camshaft Position Sensor Circuit
P0341 Intake Camshaft Position Sensor Performance
P0342 Intake Camshaft Position Sensor Circuit low voltage
P0343 Intake Camshaft Position Sensor Circuit low voltage
P0351 Ignition Coil 1 Control Circuit
P0352 Ignition Coil 2 Control Circuit
P0353 Ignition Coil 3 Control Circuit
P0354 Ignition Coil 4 Control Circuit
P0365 Exhaust Camshaft Position Sensor Circuit
P0366 Exhaust Camshaft Position Sensor Performance
P0367 Exhaust Camshaft Position Sensor Circuit Low Voltage
P0368 Exhaust Camshaft Position Sensor Circuit High Voltage
P0420 Catalyst System Low Efficiency
P0442 Evaporative Emissions System Small Leak Detected
P0443 Evaporative Emission Purge Solenoid Control Circuit
P0446 Evaporative Emissions Vent System Performance
P0449 Evaporative Emission Vent Solenoid Control Circuit
P0451 Fuel Tank Pressure Sensor Performance
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure Sensor Circuit High Voltage
P0454 Fuel Tank Pressure Sensor Intermittent
P0455 Evaporative Emission System Large Leak
P0458 Evaporative Emission Purge Solenoid Control Circuit Low Voltage
P0459 Evaporative Emission Purge Solenoid Control Circuit High Voltage
P0461 Fuel Level Sensor Circuit Performance
P0462 Fuel Level Sensor Circuit Low Voltage
P0463 Fuel Level Sensor Circuit High Voltage
P0480 Cooling Fan Relay 1 Control Circuit
P0481 Cooling Fan Relay 2 Control Circuit
P0496 Evaporative Emission System Flow During Non-Purge
P0498 Evaporative Emission Vent Solenoid Control Circuit Low Voltage
P0499 Evaporative Emission Vent Solenoid Control Circuit High Voltage
P0500 Vehicle Speed Sensor Circuit
P0502 Vehicle Speed Sensor Circuit Low Voltage
P0503 Vehicle Speed Sensor Circuit Intermittent
P0506 Idle Speed Low
P0507 Idle Speed High
P050A Cold Start Idle Air Control System Performance
P0520 Engine Oil Pressure Sensor Circuit
P0532 Air Conditioning Refrigerant Pressure Sensor Circuit Low Voltage
P0533 Air Conditioning Refrigerant Pressure Sensor Circuit High Voltage
P0556 Brake Booster Pressure Sensor Performance
P0557 Brake Booster Pressure Sensor Circuit Low Voltage
P0558 Brake Booster Pressure Sensor Circuit High Voltage
P0560 System Voltage
P0562 System Voltage  Low TCM
P0563 System Voltage  High TCM
P0571 Cruise Control Brake Switch Circuit
P0572 Brake Switch Circuit 1 Low Voltage
P0573 Brake Switch Circuit 1 High Voltage
P0575 Cruise Control Switch Signal Circuit
P0601 Control Module Read Only Memory Transmission Control Module Read Only Memory
P0602 Control Module Not Programmed Transmission Control Module Not Programmed
P0603 Control Module Long Term Memory Reset Transmission Control Module Long Term Memory Reset
P0604 Control Module Random Access Memory Transmission Control Module Random Access Memory
P0606 Control Module Internal Performance
P0607 Control Module Performance
P060D Control Module Accelerator Pedal Position System Performance
P0615 Starter Relay Control Circuit
P0616 Starter Relay Control Circuit Low Voltage
P0617 Starter Relay Control Circuit High Voltage
P0621 Generator L-Terminal Circuit
P0622 Generator F-Terminal Circuit
P0626 Generator F-Terminal Circuit High Voltage
P0627 Fuel Pump Relay Control Circuit
P0628 Fuel Pump Relay Control Circuit Low Voltage
P0629 Fuel Pump Relay Control Circuit High Voltage
P062B Control Module Fuel Injector Control Performance
P062F Control Module Long Term Memory Performance Transmission Control Module Long Term Memory Performance
P0638 Throttle Actuator Control Command Performance
P0641 5-Volt Reference 1 Circuit
P0642 5-Volt Reference 1 Low Voltage
P0643 5-Volt Reference 1 High Voltage
P0645 Air Conditioning Clutch Relay Control Circuit.
P0650 Malfunction Indicator Lamp Control Circuit
P0651 5-Volt Reference 2 Circuit
P0652 5-Volt Reference 2 Low Voltage
P0653 5-Volt Reference 2 High Voltage
P0685 Engine Controls Ignition Relay Control Circuit
P0686 Engine Controls Ignition Relay Control Circuit Low Voltage
P0687 Engine Controls Ignition Relay Control Circuit High Voltage
P0689 Engine Controls Ignition Relay Feedback Circuit Low Voltage
P0690 Engine Controls Ignition Relay Feedback Circuit High Voltage
P0691 Cooling Fan Speed Output Circuit Low Voltage
P0692 Cooling Fan Speed Output Circuit High Voltage
P0697 5-Volt Reference 3 Circuit
P0698 5-Volt Reference 3 Low Voltage
P0699 5-Volt Reference 3 High Voltage
P0700 Transmission Control Module Requested MIL Illumination
P0703 Brake Switch Circuit 2
P0711 Transmission Fluid Temperature Sensor Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Voltage
P0713 Transmission Fluid Temperature Sensor Circuit High Voltage
P0716 Input Speed Sensor Performance
P0717 Input Speed Sensor Circuit Low Voltage
P0722 Output Speed Sensor Circuit Low Voltage
P0723 Output Speed Sensor Circuit Intermittent
P0727 Engine Speed No Signal
P0741 Torque Converter Clutch System - Stuck Off
P0742 Torque Converter Clutch System - Stuck On
P0748 Pressure Control Solenoid Control Circuit
P0751 1-2 Shift Solenoid Valve Performance - No First, Fourth or Fifth Gear
P0752 1-2 Shift Solenoid Valve Performance - No Second or Third Gear
P0756 2-3 Shift Solenoid Valve Performance - No First or Second Gear
P0757 2-3 Shift Solenoid Valve Performance - No Third, Fourth or Fifth Gear
P0761 4-5 Shift Solenoid Valve Performance - No Fourth Gear
P0762 4-5 Shift Solenoid Valve Performance - No Fifth Gear
P0833 Clutch Pedal Switch 2 Circuit
P0850 Park/Neutral Position Switch Circuit
P0973 1-2 Shift Solenoid Control Circuit Low Voltage
P0974 1-2 Shift Solenoid Control Circuit High Voltage
P0976 2-3 Shift Solenoid Control Circuit Low Voltage
P0977 2-3 Shift Solenoid Control Circuit High Voltage
P0979 4-5 Shift Solenoid Control Circuit Low Voltage
P0980 4-5 Shift Solenoid Control Circuit High Voltage
P1011 Intake Camshaft Position Actuator Park Position Circuit
P1012 Intake Camshaft Position Actuator Park Position Circuit
P1101 Intake Air Flow System Performance
P1133 HO2S Insufficient Switching Sensor 1
P1174 Fuel Trim Cylinder Balance
P1400 Cold Start Emission Reduction Control System
P1516 Throttle Actuator Control Module Throttle Actuator Position Performance
P1551 Throttle Valve Rest Position Not Reached During Learn
P1629 Theft Deterrent Fuel Enable Signal Not Received
P1631 Theft Deterrent Fuel Enable Signal Not Correct
P1632 Theft Deterrent Start Disable Signal Received
P167A Control Module HO2S 1 System Performance
P167D Control Module Ignition Coil Internal Circuit
P1682 Ignition 1 Switch Circuit 2
P1793 Wheel Speed Signal
P1820 Internal Mode Switch A Circuit Low Voltage
P1822 Internal Mode Switch B Circuit High Voltage
P1823 Internal Mode Switch P Circuit Low Voltage
P1825 Internal Mode Switch - Invalid Range
P1826 Internal Mode Switch C Circuit High Voltage
P1831 Pressure Control/Shift Lock Solenoid Control Circuit Low Voltage
P1832 Pressure Control/Shift Lock Solenoid Control Circuit High Voltage
P1833 Torque Converter Clutch/Shift Solenoid Control Circuit Low Voltage
P1834 Torque Converter Clutch/Shift Solenoid Control Circuit High Voltage
P1915 Internal Mode Switch Does Not Indicate Park/Neutral During Start
P2088 Intake Camshaft Position Actuator Solenoid Control Circuit Low Voltage
P2089 Intake Camshaft Position Actuator Solenoid Control Circuit High Voltage
P2090 Exhaust Camshaft Position Actuator Solenoid Control Circuit Low Voltage
P2091 Exhaust Camshaft Position Actuator Solenoid Control Circuit High Voltage
P2096 Post Catalyst Fuel Trim System Low Limit Bank 1
P2097 Post Catalyst Fuel Trim System High Limit Bank 1
P2100 Throttle Actuator Control Motor Control Circuit
P2101 Control Module Throttle Actuator Position Performance
P2105 Throttle Actuator Control System - Forced Engine Shut-down
P2107 Throttle Actuator Control Module Internal Circuit
P2119 Throttle Closed Position Performance
P2120 Accelerator Pedal Position Sensor 1 Circuit
P2122 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P2123 Accelerator Pedal Position Sensor 1 Circuit High Voltage
P2125 Accelerator Pedal Position Sensor 2 Circuit
P2127 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
P2128 Accelerator Pedal Position Sensor 2 Circuit High Voltage
P2135 Throttle Position Sensor 1-2 Correlation
P2138 Accelerator Pedal Position Sensor 1-2 Correlation
P2146 Injector Positive Voltage Control Circuit Group 1
P2147 Injector Positive Voltage Control Circuit Group 1 Low Voltage
P2148 Injector Positive Voltage Control Circuit Group 1 High Voltage
P2149 Injector Positive Voltage Control Circuit Group 2
P2150 Injector Positive Voltage Control Circuit Group 2 Low Voltage
P2151 Injector Positive Voltage Control Circuit Group 2 High Voltage
P2152 Injector Positive Voltage Control Circuit Group 3
P2153 Injector Positive Voltage Control Circuit Group 3 Low Voltage
P2154 Injector Positive Voltage Control Circuit Group 3 High Voltage
P2155 Injector Positive Voltage Control Circuit Group 4
P2156 Injector Positive Voltage Control Circuit Group 4 Low Voltage
P2157 Injector Positive Voltage Control Circuit Group 4 High Voltage
P2176 Minimum Throttle Position Not Learned
P2177 Fuel Trim System Lean at Cruise or Accel
P2178 Fuel Trim System Rich at Cruise or Accel
P2187 Fuel Trim System Lean at Idle
P2188 Fuel Trim System Rich at Idle
P2195 HO2S Signal Biased Lean Sensor 1
P2196 HO2S Signal Biased Rich Sensor 1
P2199 Intake Air Temperature Sensor 1-2 Correlation
P2227 Barometric Pressure Sensor Performance
P2228 Barometric Pressure Sensor Circuit Low Voltage
P2229 Barometric Pressure Sensor Circuit High Voltage
P2231 HO2S Signal Circuit Shorted to Heater Circuit Sensor 1
P2232 HO2S Signal Circuit Shorted to Heater Circuit Sensor 2
P2237 HO2S Pumping Current Control Circuit Sensor 1
P2243 HO2S Reference Voltage Circuit Sensor 1
P2251 HO2S Low Reference Circuit Sensor 1
P2261 Turbocharger Bypass Valve Stuck
P2270 HO2S Signal Stuck Lean Sensor 2
P2271 HO2S Signal Stuck Rich Sensor 2
P2297 HO2S Performance During Decel Fuel Cut-Off Sensor 1
P2300 Ignition Coil 1 Control Circuit Low Voltage
P2301 Ignition Coil 1 Control Circuit High Voltage
P2303 Ignition Coil 2 Control Circuit Low Voltage
P2304 Ignition Coil 2 Control Circuit High Voltage
P2306 Ignition Coil 3 Control Circuit Low Voltage
P2307 Ignition Coil 3 Control Circuit High Voltage
P2309 Ignition Coil 4 Control Circuit Low Voltage
P2310 Control Circuit High Voltage
P2500 Generator L-Terminal Circuit Low Voltage
P2501 Generator L-Terminal Circuit High Voltage
P2535 Ignition 1 Switch Circuit High Voltage
P2544 Transmission Torque Request Circuit
P258A Vacuum Pump Relay Control Circuit
P258B Vacuum Pump Performance
P258C Vacuum Pump Relay Control Circuit Low Voltage
P258D Vacuum Pump Relay Control Circuit High Voltage
P2610 Control Module Ignition Off Timer Performance
P2626 HO2S Pumping Current Trim Circuit Sensor 1
P2637 Transmission Torque Delivered Circuit
P2763 Torque Converter Clutch Pressure Control Solenoid Control Circuit High Voltage
P2764 Torque Converter Clutch Pressure Control Solenoid Control Circuit Low Voltage
P2A00 HO2S Circuit Closed Loop Performance Sensor 1
P2A01 HO2S Circuit Sensor 2
« Last Edit: August 22, 2011, 11:51:20 AM by DeepBlueGXP »
Offline sol_man
  • Enjoying the cool summer
Re: Check Engine Light (CEL) List
« Reply #1 on: May 28, 2009, 07:58:21 AM »
 :thumbs:
Nice list, thanks!!
0-60 in 4.37 seconds
Offline IBDRINKEN
  • Donkey Master
Re: Kappa Check Engine Light (CEL) List
« Reply #2 on: August 22, 2011, 11:38:38 AM »
P0010-P0099 – Fuel and Air Metering and Auxiliary Emission Controls
* P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
* P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
* P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
* P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
* P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
* P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
* P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
* P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
* P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
* P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
* P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
* P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
* P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
* P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
* P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
* P0033 Turbo Charger Bypass Valve Control Circuit
* P0034 Turbo Charger Bypass Valve Control Circuit Low
* P0035 Turbo Charger Bypass Valve Control Circuit High
* P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
* P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
* P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
* P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
* P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
* P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
* P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
* P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
* P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
* P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
* P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
* P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
* P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
* P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
* P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
* P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
* P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
* P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
* P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
* P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
* P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
* P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
* P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
* P0065 Air Assisted Injector Control Range/Performance
* P0066 Air Assisted Injector Control Circuit or Circuit Low
* P0067 Air Assisted Injector Control Circuit High
* P0070 Ambient Air Temperature Sensor Circuit
* P0071 Ambient Air Temperature Sensor Range/Performance
* P0072 Ambient Air Temperature Sensor Circuit Low Input
* P0073 Ambient Air Temperature Sensor Circuit High Input
* P0074 Ambient Air Temperature Sensor Circuit Intermittent
* P0075 Intake Valve Control Solenoid Circuit (Bank 1)
* P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
* P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
* P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
* P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
* P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
* P0081 Intake valve Control Solenoid Circuit (Bank 2)
* P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
* P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
* P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
* P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
* P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
DTC Codes - P0100-P0199 – Fuel and Air Metering
* P0100 Mass or Volume Air Flow Circuit Malfunction
* P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
* P0102 Mass or Volume Air Flow Circuit Low Input
* P0103 Mass or Volume Air Flow Circuit High Input
* P0104 Mass or Volume Air Flow Circuit Intermittent
* P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
* P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
* P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
* P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
* P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
* P0109 Intake Air Temperature Circuit Malfunction
* P0111 Intake Air Temperature Circuit Range/Performance Problem
* P0112 Intake Air Temperature Circuit Low Input
* P0113 Intake Air Temperature Circuit High Input
* P0114 Intake Air Temperature Circuit Intermittent
* P0115 Engine Coolant Temperature Circuit Malfunction
* P0116 Engine Coolant Temperature Circuit Range/Performance Problem
* P0117 Engine Coolant Temperature Circuit Low Input
* P0118 Engine Coolant Temperature Circuit High Input
* P0119 Engine Coolant Temperature Circuit Intermittent
* P0120 Throttle Position Sensor/Switch A Circuit Malfunction
* P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
* P0122 Throttle Position Sensor/Switch A Circuit Low Input
* P0123 Throttle Position Sensor/Switch A Circuit High Input
* P0124 Throttle Position Sensor/Switch A Circuit Intermittent
* P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
* P0126 Insufficient Coolant Temperature for Stable Operation
* P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
* P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
* P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
* P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
* P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
* P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
* P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
* P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
* P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
* P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
* P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
* P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
* P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
* P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
* P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
* P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
* P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
* P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
* P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
* P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
* P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
* P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
* P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
* P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
* P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
* P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
* P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
* P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
* P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
* P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
* P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
* P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
* P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
* P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
* P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
* P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
* P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
* P0170 Fuel Trim Malfunction (Bank 1)
* P0171 System too Lean (Bank 1)
* P0172 System too Rich (Bank 1)
* P0173 Fuel Trim Malfunction (Bank 2)
* P0174 System too Lean (Bank 2)
* P0175 System too Rich (Bank 2)
* P0176 Fuel Composition Sensor Circuit Malfunction
* P0177 Fuel Composition Sensor Circuit Range/Performance
* P0178 Fuel Composition Sensor Circuit Low Input
* P0179 Fuel Composition Sensor Circuit High Input
* P0180 Fuel Temperature Sensor A Circuit Malfunction
* P0181 Fuel Temperature Sensor A Circuit Range/Performance
* P0182 Fuel Temperature Sensor A Circuit Low Input
* P0183 Fuel Temperature Sensor A Circuit High Input
* P0184 Fuel Temperature Sensor A Circuit Intermittent
* P0185 Fuel Temperature Sensor B Circuit Malfunction
* P0186 Fuel Temperature Sensor B Circuit Range/Performance
* P0187 Fuel Temperature Sensor B Circuit Low Input
* P0188 Fuel Temperature Sensor B Circuit High Input
* P0189 Fuel Temperature Sensor B Circuit Intermittent
* P0190 Fuel Rail Pressure Sensor Circuit Malfunction
* P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
* P0192 Fuel Rail Pressure Sensor Circuit Low Input
* P0193 Fuel Rail Pressure Sensor Circuit High Input
* P0194 Fuel Rail Pressure Sensor Circuit Intermittent
* P0195 Engine Oil Temperature Sensor Malfunction
* P0196 Engine Oil Temperature Sensor Range/Performance
* P0197 Engine Oil Temperature Sensor Low
* P0198 Engine Oil Temperature Sensor High
* P0199 Engine Oil Temperature Sensor Intermittent
DTC Codes - P0200-P0299 – Fuel and Air Metering (Injector Circuit)
* P0200 Injector Circuit Malfunction
* P0201 Injector Circuit Malfunction - Cylinder 1
* P0202 Injector Circuit Malfunction - Cylinder 2
* P0203 Injector Circuit Malfunction - Cylinder 3
* P0204 Injector Circuit Malfunction - Cylinder 4
* P0205 Injector Circuit Malfunction - Cylinder 5
* P0206 Injector Circuit Malfunction - Cylinder 6
* P0207 Injector Circuit Malfunction - Cylinder 7
* P0208 Injector Circuit Malfunction - Cylinder 8
* P0209 Injector Circuit Malfunction - Cylinder 9
* P0210 Injector Circuit Malfunction - Cylinder 10
* P0211 Injector Circuit Malfunction - Cylinder 11
* P0212 Injector Circuit Malfunction - Cylinder 12
* P0213 Cold Start Injector 1 Malfunction
* P0214 Cold Start Injector 2 Malfunction
* P0215 Engine Shutoff Solenoid Malfunction
* P0216 Injection Timing Control Circuit Malfunction
* P0217 Engine Overtemp Condition
* P0218 Transmission Over Temperature Condition
* P0219 Engine Overspeed Condition
* P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
* P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
* P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
* P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
* P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
* P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
* P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
* P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
* P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
* P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
* P0230 Fuel Pump Primary Circuit Malfunction
* P0231 Fuel Pump Secondary Circuit Low
* P0232 Fuel Pump Secondary Circuit High
* P0233 Fuel Pump Secondary Circuit Intermittent
* P0234 Engine Overboost Condition
* P0235 Turbocharger Boost Sensor A Circuit Malfunction
* P0236 Turbocharger Boost Sensor A Circuit Range/Performance
* P0237 Turbocharger Boost Sensor A Circuit Low
* P0238 Turbocharger Boost Sensor A Circuit High
* P0239 Turbocharger Boost Sensor B Malfunction
* P0240 Turbocharger Boost Sensor B Circuit Range/Performance
* P0241 Turbocharger Boost Sensor B Circuit Low
* P0242 Turbocharger Boost Sensor B Circuit High
* P0243 Turbocharger Wastegate Solenoid A Malfunction
* P0244 Turbocharger Wastegate Solenoid A Range/Performance
* P0245 Turbocharger Wastegate Solenoid A Low
* P0246 Turbocharger Wastegate Solenoid A High
* P0247 Turbocharger Wastegate Solenoid B Malfunction
* P0248 Turbocharger Wastegate Solenoid B Range/Performance
* P0249 Turbocharger Wastegate Solenoid B Low
* P0250 Turbocharger Wastegate Solenoid B High
* P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
* P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
* P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
* P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
* P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
* P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
* P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
* P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
* P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
* P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
* P0261 Cylinder I Injector Circuit Low
* P0262 Cylinder I Injector Circuit High
* P0263 Cylinder I Contribution/Balance Fault
* P0264 Cylinder 2 Injector Circuit Low
* P0265 Cylinder 2 Injector Circuit High
* P0266 Cylinder 2 Contribution/Balance Fault
* P0267 Cylinder 3 Injector Circuit Low
* P0268 Cylinder 3 Injector Circuit High
* P0269 Cylinder 3 Contribution/Balance Fault
* P0270 Cylinder 4 Injector Circuit Low
* P0271 Cylinder 4 Injector Circuit High
* P0272 Cylinder 4 Contribution/Balance Fault
* P0273 Cylinder 5 Injector Circuit Low
* P0274 Cylinder 5 Injector Circuit High
* P0275 Cylinder S Contribution/Balance Fault
* P0276 Cylinder 6 Injector Circuit Low
* P0277 Cylinder 6 Injector Circuit High
* P0278 Cylinder 6 Contribution/Balance Fault
* P0279 Cylinder 7 Injector Circuit Low
* P0280 Cylinder 7 Injector Circuit High
* P0281 Cylinder 7 Contribution/Balance Fault
* P0282 Cylinder 8 Injector Circuit Low
* P0283 Cylinder 8 Injector Circuit High
* P0284 Cylinder 8 Contribution/Balance Fault
* P0285 Cylinder 9 Injector Circuit Low
* P0286 Cylinder 9 Injector Circuit High
* P0287 Cylinder 9 Contribution/Balance Fault
* P0288 Cylinder 10 Injector Circuit Low
* P0289 Cylinder 10 Injector Circuit High
* P0290 Cylinder 10 Contribution/Balance Fault
* P0291 Cylinder 11 Injector Circuit Low
* P0292 Cylinder 11 Injector Circuit High
* P0293 Cylinder 11 Contribution/Balance Fault
* P0294 Cylinder 12 Injector Circuit Low
* P0295 Cylinder 12 Injector Circuit High
* P0296 Cylinder 12 Contribution/Range Fault
DTC Codes - P0300-P0399 – Ignition System or Misfire
* P0300 Random/Multiple Cylinder Misfire Detected
* P0301 Cylinder 1 Misfire Detected
* P0302 Cylinder 2 Misfire Detected
* P0303 Cylinder 3 Misfire Detected
* P0304 Cylinder 4 Misfire Detected
* P0305 Cylinder 5 Misfire Detected
* P0306 Cylinder 6 Misfire Detected
* P0307 Cylinder 7 Misfire Detected
* P0308 Cylinder 8 Misfire Detected
* P0309 Cylinder 9 Misfire Detected
* P0310 Cylinder 10 Misfire Detected
* P0311 Cylinder 11 Misfire Detected
* P0312 Cylinder 12 Misfire Detected
* P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
* P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
* P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
* P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
* P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
* P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
* P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
* P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
* P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
* P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
* P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
* P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
* P0333 Knock Sensor 2 Circuit High Input (Bank 2)
* P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
* P0335 Crankshaft Position Sensor A Circuit Malfunction
* P0336 Crankshaft Position Sensor A Circuit Range/Performance
* P0337 Crankshaft Position Sensor A Circuit Low Input
* P0338 Crankshaft Position Sensor A Circuit High Input
* P0339 Crankshaft Position Sensor A Circuit Intermittent
* P0340 Camshaft Position Sensor Circuit Malfunction
* P0341 Camshaft Position Sensor Circuit Range/Performance
* P0342 Camshaft Position Sensor Circuit Low Input
* P0343 Camshaft Position Sensor Circuit High Input
* P0344 Camshaft Position Sensor Circuit Intermittent
* P0350 Ignition Coil Primary/Secondary Circuit Malfunction
* P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
* P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
* P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
* P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
* P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
* P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
* P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
* P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
* P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
* P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
* P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
* P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
* P0370 Timing Reference High Resolution Signal A Malfunction
* P0371 Timing Reference High Resolution Signal A Too Many Pulses
* P0372 Timing Reference High Resolution Signal A Too Few Pulses
* P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
* P0374 Timing Reference High Resolution Signal A No Pulses
* P0375 Timing Reference High Resolution Signal B Malfunction
* P0376 Timing Reference High Resolution Signal B Too Many Pulses
* P0377 Timing Reference High Resolution Signal B Too Few Pulses
* P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
* P0379 Timing Reference High Resolution Signal B No Pulses
* P0380 Glow Plug/Heater Circuit "A" Malfunction
* P0381 Glow Plug/Heater Indicator Circuit Malfunction
* P0382 Exhaust Gas Recirculation Flow Malfunction
* P0385 Crankshaft Position Sensor B Circuit Malfunction
* P0386 Crankshaft Position Sensor B Circuit Range/Performance
* P0387 Crankshaft Position Sensor B Circuit Low Input
* P0388 Crankshaft Position Sensor B Circuit High Input
* P0389 Crankshaft Position Sensor B Circuit Intermittent
DTC Codes - P0400-P0499 – Auxiliary Emissions Controls
* P0400 Exhaust Gas Recirculation Flow Malfunction
* P0401 Exhaust Gas Recirculation Flow Insufficient Detected
* P0402 Exhaust Gas Recirculation Flow Excessive Detected
* P0403 Exhaust Gas Recirculation Circuit Malfunction
* P0404 Exhaust Gas Recirculation Circuit Range/Performance
* P0405 Exhaust Gas Recirculation Sensor A Circuit Low
* P0406 Exhaust Gas Recirculation Sensor A Circuit High
* P0407 Exhaust Gas Recirculation Sensor B Circuit Low
* P0408 Exhaust Gas Recirculation Sensor B Circuit High
* P0410 Secondary Air Injection System Malfunction
* P0411 Secondary Air Injection System Incorrect Flow Detected
* P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
* P0413 Secondary Air Injection System Switching Valve A Circuit Open
* P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
* P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
* P0416 Secondary Air Injection System Switching Valve B Circuit Open
* P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
* P0418 Secondary Air Injection System Relay ‘A" Circuit Malfunction
* P0419 Secondary Air Injection System Relay "B’ Circuit Malfunction
* P0420 Catalyst System Efficiency Below Threshold (Bank 1)
* P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
* P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
* P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
* P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
* P0430 Catalyst System Efficiency Below Threshold (Bank 2)
* P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
* P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
* P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
* P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
* P0440 Evaporative Emission Control System Malfunction
* P0441 Evaporative Emission Control System Incorrect Purge Flow
* P0442 Evaporative Emission Control System Leak Detected (small leak)
* P0443 Evaporative Emission Control System Purge Control Valve Circuit
* P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
* P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
* P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
* P0447 Evaporative Emission Control System Vent Control Circuit Open
* P0448 Evaporative Emission Control System Vent Control Circuit Shorted
* P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
* P0450 Evaporative Emission Control System Pressure Sensor Malfunction
* P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
* P0452 Evaporative Emission Control System Pressure Sensor Low Input
* P0453 Evaporative Emission Control System Pressure Sensor High Input
* P0454 Evaporative Emission Control System Pressure Sensor Intermittent
* P0455 Evaporative Emission Control System Leak Detected (gross leak)
* P0456 Evaporative Emissions System - Small leak detected
* P0457
* P0458
* P0459
* P0460 Fuel Level Sensor Circuit Malfunction
* P0461 Fuel Level Sensor Circuit Range/Performance
* P0462 Fuel Level Sensor Circuit Low Input
* P0463 Fuel Level Sensor Circuit High Input
* P0464 Fuel Level Sensor Circuit Intermittent
* P0465 Purge Flow Sensor Circuit Malfunction
* P0466 Purge Flow Sensor Circuit Range/Performance
* P0467 Purge Flow Sensor Circuit Low Input
* P0468 Purge Flow Sensor Circuit High Input
* P0469 Purge Flow Sensor Circuit Intermittent
* P0470 Exhaust Pressure Sensor Malfunction
* P0471 Exhaust Pressure Sensor Range/Performance
* P0472 Exhaust Pressure Sensor Low
* P0473 Exhaust Pressure Sensor High
* P0474 Exhaust Pressure Sensor Intermittent
* P0475 Exhaust Pressure Control Valve Malfunction
* P0476 Exhaust Pressure Control Valve Range/Performance
* P0477 Exhaust Pressure Control Valve Low
* P0478 Exhaust Pressure Control Valve High
* P0479 Exhaust Pressure Control Valve Intermittent
* P0480 Cooling Fan I Control Circuit Malfunction
* P0481 Cooling Fan 2 Control Circuit Malfunction
* P0482 Cooling Fan 3 Control Circuit Malfunction
* P0483 Cooling Fan Rationality Check Malfunction
* P0484 Cooling Fan Circuit Over Current
* P0485 Cooling Fan Power/Ground Circuit Malfunction
DTC Codes - P0500-P0599 – Vehicle Speed Controls and Idle Control System
* P0500 Vehicle Speed Sensor Malfunction
* P0501 Vehicle Speed Sensor Range/Performance
* P0502 Vehicle Speed Sensor Low Input
* P0503 Vehicle Speed Sensor Intermittent/Erratic/High
* P0505 Idle Control System Malfunction
* P0506 Idle Control System RPM Lower Than Expected
* P0507 Idle Control System RPM Higher Than Expected
* P0510 Closed Throttle Position Switch Malfunction
* P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
* P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
* P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
* P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
* P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
* P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
* P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
* P0533 A/C Refrigerant Pressure Sensor Circuit High Input
* P0534 Air Conditioner Refrigerant Charge Loss
* P0550 Power Steering Pressure Sensor Circuit Malfunction
* P0551 Power Steering Pressure Sensor Circuit Range/Performance
* P0552 Power Steering Pressure Sensor Circuit Low Input
* P0553 Power Steering Pressure Sensor Circuit High Input
* P0554 Power Steering Pressure Sensor Circuit Intermittent
* P0560 System Voltage Malfunction
* P0561 System Voltage Unstable
* P0562 System Voltage Low
* P0563 System Voltage High
* P0565 Cruise Control On Signal Malfunction
* P0566 Cruise Control Off Signal Malfunction
* P0567 Cruise Control Resume Signal Malfunction
* P0568 Cruise Control Set Signal Malfunction
* P0569 Cruise Control Coast Signal Malfunction
* P0570 Cruise Control Accel Signal Malfunction
* P0571 Cruise Control/Brake Switch A Circuit Malfunction
* P0572 Cruise Control/Brake Switch A Circuit Low
* P0573 Cruise Control/Brake Switch A Circuit High
* P0574 Cruise Control Related Malfunction
* P0575 Cruise Control Related Malfunction
* P0576 Cruise Control Related Malfunction
* P0578 Cruise Control Related Malfunction
* P0579 Cruise Control Related Malfunction
* P0580 Cruise Control Related Malfunction
DTC Codes - P0600-P0699 – Computer Output Circuit
* P0600 Serial Communication Link Malfunction
* P0601 Internal Control Module Memory Check Sum Error
* P0602 Control Module Programming Error
* P0603 Internal Control Module Keep Alive Memory (KAM) Error
* P0604 Internal Control Module Random Access Memory (RAM) Error
* P0605 Internal Control Module Read Only Memory (ROM) Error
* P0606 PCM Processor Fault
* P0608 Control Module VSS Output "A’ Malfunction
* P0609 Control Module VSS Output "B" Malfunction
* P0620 Generator Control Circuit Malfunction
* P0621 Generator Lamp "L" Control Circuit Malfunction
* P0622 Generator Field "F" Control Circuit Malfunction
* P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
* P0654 Engine RPM Output Circuit Malfunction
* P0655 Engine Hot Lamp Output Control Circuit Malfunction
* P0656 Fuel Level Output Circuit Malfunction
DTC Codes - P0700-P0899 – Transmission
* P0700 Transmission Control System Malfunction
* P0701 Transmission Control System Range/Performance
* P0702 Transmission Control System Electrical
* P0703 Torque Converter/Brake Switch B Circuit Malfunction
* P0704 Clutch Switch Input Circuit Malfunction
* P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
* P0706 Transmission Range Sensor Circuit Range/Performance
* P0707 Transmission Range Sensor Circuit Low Input
* P0708 Transmission Range Sensor Circuit High Input
* P0709 Transmission Range Sensor Circuit Intermittent
* P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
* P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
* P0712 Transmission Fluid Temperature Sensor Circuit Low Input
* P0713 Transmission Fluid Temperature Sensor Circuit High Input
* P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
* P0715 Input/Turbine Speed Sensor Circuit Malfunction
* P0716 Input/Turbine Speed Sensor Circuit Range/Performance
* P0717 Input/Turbine Speed Sensor Circuit No Signal
* P0718 Input/Turbine Speed Sensor Circuit Intermittent
* P0719 Torque Converter/Brake Switch B Circuit Low
* P0720 Output Speed Sensor Circuit Malfunction
* P0721 Output Speed Sensor Range/Performance
* P0722 Output Speed Sensor No Signal
* P0723 Output Speed Sensor Intermittent
* P0724 Torque Converter/Brake Switch B Circuit High
* P0725 Engine Speed input Circuit Malfunction
* P0726 Engine Speed Input Circuit Range/Performance
* P0727 Engine Speed Input Circuit No Signal
* P0728 Engine Speed Input Circuit Intermittent
* P0730 Incorrect Gear Ratio
* P0731 Gear I Incorrect ratio
* P0732 Gear 2 Incorrect ratio
* P0733 Gear 3 Incorrect ratio
* P0734 Gear 4 Incorrect ratio
* P0735 Gear 5 Incorrect ratio
* P0736 Reverse incorrect gear ratio
* P0740 Torque Converter Clutch Circuit Malfunction
* P0741 Torque Converter Clutch Circuit Performance or Stuck Off
* P0742 Torque Converter Clutch Circuit Stock On
* P0743 Torque Converter Clutch Circuit Electrical
* P0744 Torque Converter Clutch Circuit Intermittent
* P0745 Pressure Control Solenoid Malfunction
* P0746 Pressure Control Solenoid Performance or Stuck Off
* P0747 Pressure Control Solenoid Stuck On
* P0748 Pressure Control Solenoid Electrical
* P0749 Pressure Control Solenoid Intermittent
* P0750 Shift Solenoid A Malfunction
* P0751 Shift Solenoid A Performance or Stuck Off
* P0752 Shift Solenoid A Stuck On
* P0753 Shift Solenoid A Electrical
* P0754 Shift Solenoid A Intermittent
* P0755 Shift Solenoid B Malfunction
* P0756 Shift Solenoid B Performance or Stock Off
* P0757 Shift Solenoid B Stuck On
* P0758 Shift Solenoid B Electrical
* P0759 Shift Solenoid B Intermittent
* P0760 Shift Solenoid C Malfunction
* P0761 Shift Solenoid C Performance or Stuck Off
* P0762 Shift Solenoid C Stuck On
* P0763 Shift Solenoid C Electrical
* P0764 Shift Solenoid C Intermittent
* P0765 Shift Solenoid D Malfunction
* P0766 Shift Solenoid D Performance or Stuck Off
* P0767 Shift Solenoid D Stuck On
* P0768 Shift Solenoid D Electrical
* P0769 Shift Solenoid D Intermittent
* P0770 Shift Solenoid E Malfunction
* P0771 Shift Solenoid E Performance or Stuck Off
* P0772 Shift Solenoid E Stuck On
* P0773 Shift Solenoid E Electrical
* P0774 Shift Solenoid E Intermittent
* P0780 Shift Malfunction
* P0781 1-2 Shift Malfunction
* P0782 2-3 Shift Malfunction
* P0783 3-4 Shift Malfunction
* P0784 4-5 Shift Malfunction
* P0785 Shift/Timing Solenoid Malfunction
* P0786 Shift/Timing Solenoid Range/Performance
* P0787 Shift/Timing Solenoid Low
* P0788 Shift/Timing Solenoid High
* P0789 Shift/Timing Solenoid Intermittent
* P0790 Normal/Performance Switch Circuit Malfunction
* P0801 Reverse Inhibit Control Circuit Malfunction
* P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
* P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0A00-P0A99 – Transmission Code Description
P0A00 Motor Electronics Coolant Temperature Sensor Circuit
P0A01 Motor Electronics Coolant Temperature Sensor Circuit Range/Performance
P0A02 Motor Electronics Coolant Temperature Sensor Circuit Low
P0A03 Motor Electronics Coolant Temperature Sensor Circuit High
P0A04 Motor Electronics Coolant Temperature Sensor Circuit Intermittent
P0A05 Motor Electronics Coolant Pump Control Circuit/Open
P0A06 Motor Electronics Coolant Pump Control Circuit Low
P0A07 Motor Electronics Coolant Pump Control Circuit High
P0A08 DC/DC Converter Status Circuit
P0A09 DC/DC Converter Status Circuit Low Input
P0A10 DC/DC Converter Status Circuit High Input
P0A11 DC/DC Converter Enable Circuit/Open
P0A12 DC/DC Converter Enable Circuit Low
P0A13 DC/DC Converter Enable Circuit High
P0A14 Engine Mount Control Circuit/Open
P0A15 Engine Mount Control Circuit Low
P0A16 Engine Mount Control Circuit High
P0A17 Motor Torque Sensor Circuit
P0A18 Motor Torque Sensor Circuit Range/Performance
P0A19 Motor Torque Sensor Circuit Low
P0A20 Motor Torque Sensor Circuit High
P0A21 Motor Torque Sensor Circuit Intermittent
P0A22 Generator Torque Sensor Circuit
P0A23 Generator Torque Sensor Circuit Range/Performer
P0A24 Generator Torque Sensor Circuit Low
P0A25 Generator Torque Sensor Circuit High
P0A26 Generator Torque Sensor Circuit Intermittent
P0A27 Battery Power Off Circuit
P0A28 Battery Power Off Circuit Low
P0A29 Battery Power Off Circuit High
P1100-P1199 – Fuel and Air Metering Code Description
P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
P1101 MAF Sensor Out Of Self Test Range
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 IAT Sensor Open/Short
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 Throttle position sensor out of range
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1123 Throttle Position Sensor In Range But Higher Than Expected
P1124 Throttle Position Sensor Out Of Self Test Range
P1125 Throttle position sensor intermittent
P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S Switch - Sensor Indicates Lean
P1132 Lack Of HO2S Switch - Sensor Indicates Rich
P1134 HO2S Transition Time Ratio Sensor 1
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Fan Control Circuit Malfunction
P1137 Lack Of HO2S Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean
P1154 Bank 2 Fuel Control Shifted Rich
P1155 Alternative Fuel Controller
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test,throttle not depressed
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronization Fault
P1178 ( open )
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 Voltage External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1200-P1299 – Fuel and Air Metering Code Description
P1200 Injector Control Circuit
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 THEFT Detected, Vehicle Immobilzed
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM Or Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1280 Injection Control Pressure Out Of Range Low
P1281 Injection Control Pressure Out Of Range High
P1282 Excessive Injection Control Pressure
P1283 IPR Circuit Failure
P1284 Aborted KOER - ICP Failure
P1285 Cylinder head over temp sensed
P1286 Fuel Pulse In Range But Lower Than Expected
P1287 Fuel Pulse In Range But Higher Than Expected
P1288 Cylinder Head Temp Sensor Out Of Self Test Range
P1289 Cylinder Head Temp Sensor High Input
P1290 Cylinder Head Temp Sensor Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2/Target idle not reached
P1295 Multi-faults - Bank 1 - With Low Side Shorts
P1296 Multi-faults - Bank 2 - With Low Side Shorts
P1297 Injector High Sides Shorted Together
P1298 IDM Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300-P1399 – Ignition System or Misfire Code Description
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 EGR Calibration Fault
P1304 EGR Calibration High
P1305 EGR Calibration Low
P1306 Kickdown Relay Pull - In Circuit Fault
P1307 Kickdown Relay Hold Circuit Fault
P1308 A/C Clutch Circuit Fault
P1309 Misfire Monitor AICE Chip Fault
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Circuit / IDM Codes Detected
P1317 Injector Circuit / IDM Codes Not Updated
P1336 Crank / Cam Sensor Range / Performance
P1340 Camshaft Position Sensor B Circuit Malfunction
P1341 Camshaft Position Sensor B Range / Performance
P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
P1346 Fuel Level Sensor B Circuit Malfunction
P1347 Fuel Level Sensor B Range / Performance
P1348 Fuel Level Sensor B Circuit Low
P1349 Fuel Level Sensor B Circuit High
P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352 Ignition Coil A Primary Circuit Malfunction
P1353 Ignition Coil B Primary Circuit Malfunction
P1354 Ignition Coil C Primary Circuit Malfunction
P1355 Ignition Coil D Primary Circuit Malfunction
P1360 Ignition Coil A Secondary Circuit Malfunction
P1361 Ignition Control (IC) Circuit Low Voltage
P1362 Ignition Coil C Secondary Circuit Malfunction
P1363 Ignition Coil D Secondary Circuit Malfunction
P1364 Ignition Coil Primary Circuit Failure
P1365 Ignition Coil Secondary Circuit Failure
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Monitor Failure
P1370 Insufficient RMP Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383 Variable Cam Timing Overretarded (Bank #1)
P1384 VVT Solenoid A Malfunction
P1385 Variable Cam Timing Solenoid B Malfunction
P1386 Variable Cam Timing Overadvanced (Bank #2)
P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388 Variable Cam Timing Overretarded (Bank #2)
P1389 Glow Plug Circuit High Side Low Input
P1390 Octane Adjust Pin Out Of Self Test Range
P1391 Glow Plug Circuit Low Input (Bank #1)
P1392 Glow Plug Circuit High Input (Bank #1)
P1393 Glow Plug Circuit Low Input (Bank #2)
P1394 Glow Plug Circuit High Input (Bank #2)
P1395 Glow Plug Monitor Fault (Bank #1)
P1396 Glow Plug Monitor Fault (Bank #2)
P1397 System Voltage Out Of Self Test Range
P1398 VVT Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P1400-P1499 – Auxiliary Emission Controls Code Description
P1400 DPFE Circuit Low Input
P1401 DPFE Circuit High Input
P1402 EGR Metering Orifice Restricted
P1403 DPFE Sensor Hoses Reversed
P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1405 DPFE Sensor Upstream Hose Off Or Plugged
P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
P1407 EGR No Flow Detected
P1408 EGR Flow Out Of Self Test Range
P1409 EVR Control Circuit Malfunction
P1411 SAI System Incorrect Downstream Flow Detected
P1413 SAI System Monitor Circuit Low Input
P1414 SAI System Monitor Circuit High Input
P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
P1417 Port Air Relief Circuit Malfunction
P1418 Split Air #1 Circuit Malfunction
P1419 Split Air #2 Circuit Malfunction
P1420 Catalyst Temperature Sensor Failure
P1421 Catalyst Damage
P1422 EGI Temperature Sensor Failure
P1423 EGI Functionality Test Failed
P1424 EGI Glow Plug Primary Failure
P1425 EGI Glow Plug Secondary Failure
P1426 EGI Mini - MAF Failed Out Of Range
P1427 EGI Mini - MAF Failed Short Circuit
P1428 EGI Mini - MAF Failed Open Circuit
P1429 Electric Air Pump Primary Failure
P1430 Electric Air Pump Secondary Failure
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low
P1437 A/C Evaporator Air Temperature Circuit High
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temperature Switch Circuit Malfunction
P1440 Purge Valve Stuck Open
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1442 Evaporative Emission Control System Leak Detected
P1443 Evaporative Emission Control System Control Valve
P1444 Purge Flow Sensor Circuit Low Input
P1445 Purge Flow Sensor Circuit High Input
P1446 Evaporative Vac Solenoid Circuit Malfunction
P1447 ELC System Closure Valve Flow Fault
P1448 ELC System 2 Fault
P1449 Evaporative Check Solenoid Circuit Malfunction
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1451 Evap Emission Control Sys Vent Control Valve Circuit
P1452 Unable To Bleed - Up Vacuum in Tank
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative System Vacuum Test Malfunction
P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
P1456 Fuel Tank Temperature Sensor Circuit Malfunction
P1457 Unable To Pull Vacuum In Tank
P1460 Wide open throttle A/C cutoff relay circuit
P1461 A/C pressure sensor circuit voltage low
P1462 A/C pressure sensor circuit voltage high
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out of Self Test Range
P1465 A/C Relay Circuit Malfunction
P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467 A/C Compressor Temperature Sensor Malfunction
P1468 SSPOD Open Circuit or Closed Circuit Fault
P1469 Low A/C Cycling Period
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473 Fan Secondary High With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1475 Fan Relay (Low) Circuit Malfunction
P1476 Fan Relay (High) Circuit Malfunction
P1477 Additional Fan Relay Circuit Malfunction
P1478 Cooling Fan Driver Fault
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low with Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Power To Fan Circuit Overcurrent
P1484 Open Power To Ground VCRM
P1485 EGRV Circuit Malfunction
P1486 EGRA Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
P1490 Secondary Air Relief Solenoid Circuit Malfunction
P1491 Secondary Switch Solenoid Circuit Malfunction
P1492 APLSOL Solenoid Circuit Malfunction
P1493 RCNT Solenoid Circuit Malfunction
P1494 SPCUT Solenoid Circuit Malfunction
P1495 TCSPL Solenoid Circuit Malfunction
P1500-P1599 – Vehicle Speed, Idle Control and Auxiliary Inputs Code Description
P1500 Vehicle Speed Sensor Intermittent
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle
P1600-P1699 – Computer Output Circuit Code Description
P1600 Loss of KAM Power; Open Circuit
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 EEPROM Malfunction
P1604 Code Word Unregestered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay O/P Circuit Malfunction
P1607 MIL O/P Circuit Malfunction
P1608 Internal ECM Malfunction
P1609 Diagnostic Lamp Driver Fault
P1610 SBDS Interactive Codes
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti Theft System
P1625 B+ Supply To VCRM Fan Circuit Malfunction
P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input Malfunction
P1629 Internal Voltage Regulator Malfunction
P1630 Internal Vref Malfunction
P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P1633 KAM Voltage Too Low
P1634 Data Output Link Circuit Failure
P1635 Tire / Axle Ratio Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
P1638 Can Link ECM/INSTM Circuit / Network Malfunction
P1639 Vehicle ID Block Corrupted or Not Programmed
P1640 Powertrain DTCs Available in Another Module
P1641 Fuel Pump Primary Circuit Failure
P1642 Fuel Pump Monitor Circuit High Input
P1643 Fuel Pump Monitor Circuit Low Input
P1644 Fuel Pump Speed Control Circuit Malfunction
P1645 Fuel Pump Resistor Switch Circuit Malfunction
P1650 PSP Switch Out of Self Test Range
P1651 PSP Switch Input Malfunction
P1652 IAC Monitor Disabled by PSP Switch Failed On
P1653 Power Steering Output Circuit Malfunction
P1654 Recirculation Override Circuit Malfunction
P1655 Starter Disable Circuit Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 IDM_EN Circuit Failure
P1663 Fuel Demand Command Signal Circuit Malfunction
P1667 CI Circuit Malfunction
P1668 PCM - IDM Communications Error
P1670 Electronic Feedback Signal Not Detected
P1680 Metering Oil Pump Malfunction
P1681 Metering Oil Pump Malfunction
P1682 Metering Oil Pump Malfunction
P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
P1689 Oil Pressure Control Solenoid Circuit Malfunction
P1690 Wastegate Solenoid Circuit Malfunction
P1691 Turbo Pressure Control Solenoid Circuit Malfunction
P1692 Turbo Control Solenoid Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
P1700-P1799 – Transmission Code Description
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 TRS Circuit Intermittent Malfunction
P1703 Brake Switch Out Of Self Test Range
P1704 Digital TRS Failed to Transition States in KOEO / KOER
P1705 Not in P or N During KOEO / KOER
P1706 High Vehicle Speed Observed in Park
P1707 Transfer Case Neutral Indicator Hard Fault Present
P1708 Clutch Switch Circuit Malfunction
P1709 PNP Switch Out Of Self Test Range
P1711 TFT Sensor Out Of Self Test Range
P1712 Trans Torque Reduction Request Signal Malfunction
P1713 TFT Sensor In Range Failure Low Value
P1714 SSA Inductive Signature Malfunction
P1715 SSB Inductive Signature Malfunction
P1716 SSC Inductive Signature Malfunction
P1717 SSD Inductive Signature Malfunction
P1718 TFT Sensor In Range Failure High
P1720 Vehicle Speed (Meter) Circuit Malfunction
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error
P1729 4x4 Low Switch Error
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1739 Slip Solenoid System
P1740 Torque Converter Clutch Inductive Signature Malfunction
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Failed On
P1743 Torque Converter Clutch Solenoid Failied On
P1744 Torque Converter Clutch System Performance
P1745 Line Pressure Solenoid System
P1746 Pressure Control Solenoid "A" Open Circuit
P1747 Pressure Control Solenoid "A" Short Circuit
P1748 EPC Malfunction
P1749 Pressure Control Solenoid Failed Low
P1751 Shift Solenoid A Performance
P1754 Coast Clutch Solenoid Circuit Malfunction
P1755 Intermediate Speed Sensor (ISS) Malfunction
P1756 Shift Solenoid B Performance
P1760 Pressure Control Solenoid "A" Short Circuit
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1765 Timing Solenoid Circuit Malfunction
P1767 Torque Converter Clutch Circuit Malfunction
P1768 Performance / Normal / Winter Mode Input Malfunction
P1769 AG4 Transmission Torque Modulation Fault
P1770 Clutch Solenoid Circuit Malfunction
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration Fault
P1777 Ignition Retard Request Circuit Fault
P1778 Transmission Reverse I/P Circuit Malfunction
P1779 TCIL Circuit Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781 4X4 Switch Out of Self Test Range
P1782 P/ES Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid "B" Open Circuit
P1789 Pressure Control Solenoid "B" Short Circuit
P1790 TP (Mechanical) Circuit Malfunction
P1791 TP (Electric) Circuit Malfunction
P1792 Barometer Pressure Circuit Malfunction
P1793 Intake Air Volume Circuit Malfunction
P1794 Battery Voltage Circuit Malfunction
P1795 Idle Switch Circuit Malfunction
P1796 Kick Down Switch Circuit Malfunction
P1797 Neutral Switch Circuit Malfunction
P1798 Coolant Temperature Circuit Malfunction
P1799 Hold Switch Circuit Malfunction
P1800-P1899 – Transmission Code Description
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
« Last Edit: August 22, 2011, 12:27:21 PM by IBDRINKEN »
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
