on my dashhawk i have volts, iat, knock retard, oil temp, coolant temp, and afr. i keep the dic on the boost function....for what i want it to do it is perfect for me. you can also clear codes, but all obd2 readers have this at this point. Kelu, to compliment the looks of your car, the aeroforce gauge in a pillar pod looks pro and tight. better than a square box mounted somewhere. i have seen someone make a cutout to inlay the gauge, but that isn't for me. Mine is mounted on the steering colum in front of the spedo pod. its in my line of sight and i don't care that i can't see the speedo numbers from 20pmh to zero. who looks at those numbers anyway right?
